Nous sommes actuellement le 30 Oct 2026, 16:44
 Sujet du message: Guidon dan-moto ebay
MessagePublié: 03 Août 2011, 16:35
C'est pour les acheteurs du bracelets guidon cafe, achat sur ebay a danmoto.
En anglais, mais une mec ici faire une bon traduction, svp :)
Dear Danmoto Customer,
Thank you for your purchase of our Adjustable Motorcycle Clip On Handlebars.
Unfortunately we have to inform you that we're initiating a product recall on this specific item.
- What is the issue?
Each side of the Handlebar consists of 3 parts.
(1) The clamp which holds the handlebar on the motorcycle fork.
(2) A tubular extension which connects the clamp (1) with the bar (3) itself.
(3) The bar
The bar again consists of 2 parts, the bar tube and the bar clamp. The bar clamp is bolted into the bar tube.
If both parts are properly assembled the bar clamp is bolted into the bar tube with a torque of 28Nm and the thread is secured with medium strength Thread locker.
In this way all forces from the bar tube are conducted into the clamp over the pressure on the contact surface.
Unfortunately a batch of about 20-30pc of the bars are incorrectly assembled. The bar clamp has not been bolted in to the correct torque and thread locker was not or insufficiently applied.
On the affected handlebars loads applied on the bar tube cannot be correctly conducted into the bar clamp and result in ongoing deformations of the bolted connection between the parts.
Depending on the load situation the bolted connection can fail after a longer time of these deformations, which can cause dangerous driving situations. Danmoto recognized 2 cases in which bars failed, fortunately without harmful results for driver or bike.
- What needs to be done?
The handlebars are not equipped with a serial number, due to this it is not possible for us to identify the affected batch and we recall the full product range of these handlebars.
We offer two options for the recall:
(1) You can return the item in any condition for a full refund inc shipping costs.
(2) If you supply us with your shipping address and handlebar model, we will send you immediately replacements for the bar clamps with an advanced design.
Please inform us about your preference by replying to this email.
The new design features a double threaded bolt which eases assembly and which is made of a high strength, ductile steel alloy which will assure a proper load conduction between the parts even in the case of improper assembly.
The parts will be supplied with detailed installation instructions.
This design modification is also carried on in the actual production and applied on all handlebars sold after May 25th 2011.
- Is it safe to use the handlebars before installation of the new bar clamp?
You can identify the affected handlebars by a small amount of free play on the bars. The affected bars can distort slightly on the connection between the bar tube and the bar clamp which results in a small free movement of the tube.
If you find this symptom on your handlebars of if you’re unsure we suggest refraining from usage until the components are exchanged.
If you sold or gave the handlebar to somebody else, we kindly ask to pass on the information of this recall to the actual owner of the items.
Hereby we want to sincerely apologize for any inconvenience caused by this product recall.
With best regards
Danmoto
 Sujet du message: Re: Guidon dan-moto ebay
MessagePublié: 03 Août 2011, 17:01
en gros :
ceux qui ont acheté des bracos dan moto doivent les renvoyer a la charge du vendeur (dan moto quoi) par ce qu'il y a une petite série de 20 / 30 pièces qui n'ont pas été assemblées correctement, ce qui peu entrainer des situations dangeureuse. un jeu peu apparaitre sur un guidon et aller jusqu'a se détacher.
deux solutions s'offre a vous : soit demander un remboursement total du produit, fdp et fdr inclus, soit demander son remplacement par un nouveau model sans frais supplementaire.
bien sur si vous avez revendu les bracos a quelqu'un, faite lui passer l'info
MessagePublié: 03 Août 2011, 19:40
Sinon y'a gogole traduction. C'est un peu du mot a mot mais c'est comprehensible... :salut:
legaragedepossum.free.fr
MessagePublié: 04 Août 2011, 12:10
ce genre d'histoire confirme un peu la pensée de certains que les pieces pas cher venant d'asie sont peut etre de moins bonne qualitées...
par contre,c'est tres bien et tres professionnel de la part de dan-moto de faire une campagne de rappelle mais en meme temps,sur des guidons bracelets,ça peut jouer sur la vie d'un homme et ça peut lui couter tres cher aussi...
sur une moto,il y a des pieces où l'on peut se permettre de prendre du "made in china" mais tout ce qui peut jouer sur la sécurité,je pense qu'il vaut mieux eviter! :siffle:
MessagePublié: 04 Août 2011, 13:48
apparament il y a déjà eu deux cas ou le guidon a du se barrer en route, mais sanscauser de blessures
MessagePublié: 04 Août 2011, 15:07
:pain: :pain: :pain: savent pas souder les chintoks
MessagePublié: 04 Août 2011, 15:14
le truc c'est que c'est pas soudé, c'est visé ou emmanché a un couple de 28Nm et lockiter, et la apparament ca a pas été fait au bon couple, d'ou le souci. mais c'est vrais qu'une soudure aurait évité ces désagréments
MessagePublié: 04 Août 2011, 16:28
Pour être honnête, tout la email ses conneries. Et envoyeur se couvrant seulement.
Mon ami qui ils ont envoyé l'avis, a été propriétaire de deux ensembles de le guidon, et ont dû les contacter au sujet de l'échec.
Et nous savons de 5 autres avec le même problème. Ainsi «deux affectés" sont des "bullshit" aussi.
Ils ont également affirmé avoir essayé de contacter mon amie à 3 reprises pour l'avertir de la défectuosité, mais tant qu'il a pris contact, il n'a reçu aucun email de leur part.
Le principal problème est qu'ils sont fabriqués à partir de fromage, plutôt que de la bonne nuance de l'alliage. Ils ont l'air bien, mais si vous n'avez pas l'équipement pour analyser la qualité, vous ne pouvez pas savoir si elles sont bonnes. Si elles avaient été fabriquées dans un grade connus tels que 7075, la question n'aurait pas surgi. Ils sont probablement la série 4000 normalment pour fab les fourche pour manger et plus, parce-que c'est moins cher...
Le guidon, ils sont conçus de copie soit 7075 ou en acier avec plaque chromée.
La dernier anne c'est la repose pieds "yoshimura" de plus, une copie d'une conception connue, mais dans un matériau de qualité qui les rend dangereux.
Ce n'est pas du snobisme. Il n'est pas non les ignorer pour être bon marché. Je fais mes pièces, car je n'ai pas les fonds pour acheter les pièces spéciales, et je deja achet pieces a dan-moto. Mais il s'agit de prendre une moto qui est sécuritaire d'utiliser de manière fiable.
Je ne vis de leurs equipments sur ma moto en une fonctione critique. Ma pièce est le compteur seulement...
Renthal's fatbars pour moi svp ;)
MessagePublié: 05 Août 2011, 11:42
Mon ami a envoyé des photos. Et ... Oh là là ...
Ce n'est pas causée par une valeur de couple mal. Son causée par le design.
Le diamètre ne doit pas réduire à entrer dans la partie suivante, la réduction des causes d'une faiblesse au point où il demande le plus de force. Très pauvre.
vous pouvez voir les marques où le flex commence à le casser avec le temps, puis un jour ne suffit pas de diamètre est à gauche, et le boom de * *. C'est un piège mortel.
MessagePublié: 26 Août 2011, 14:34
En gros ce qu'il disent peut se résumer à "chinese crap" :pain: :pain: :pain:
