Nous sommes actuellement le 02 Nov 2026, 22:33
Publier un nouveau sujet Répondre au sujet  [ 562 messages ]  Aller à la page Précédent  1 ... 12, 13, 14, 15, 16, 17, 18 ... 38  Suivant
MessagePublié: 23 Mars 2012, 19:01
:ptdr:
MessagePublié: 23 Mars 2012, 19:14
Ooh loulou tas dja vu une meule en bois ?! Mdr
MessagePublié: 23 Mars 2012, 20:52
en meme temps il a tout ficnoler les aretes alors pourkoi pas !!!! :pain:
MessagePublié: 23 Mars 2012, 22:13
Little update
Started covering the tail, my home made sheet alloy folder :)
Paper template and cut section
Section folded, fitted and help in place with screws (the screws holes will be filled with weld and rubbed down) sections trimmed with good angles for welding
tried to get a silhouette outline but it didn't work :D
MessagePublié: 23 Mars 2012, 23:17
:love: :love: :love: :love:
MessagePublié: 23 Mars 2012, 23:22
So you keep the wood inside the metal sheet? :confused:
MessagePublié: 23 Mars 2012, 23:25
:bounce: no, i make the bottom section and get them welded together, make the front section, remove the wood pattern then weld the front on.
MessagePublié: 23 Mars 2012, 23:31
Better! :tchin:
Thanks for sharing!
MessagePublié: 24 Mars 2012, 12:36
The monster 8D
MessagePublié: 24 Mars 2012, 15:53
:monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey: :monkey:
MessagePublié: 24 Mars 2012, 15:55
+1 :pain:
MessagePublié: 24 Mars 2012, 21:32
Le seul gros problème avec cette préparation c'est ... Que ça ne va pas assez vite ! On en veut encore !
MessagePublié: 25 Mars 2012, 01:57
:bave: :bave: :bave: :bave:
par contre un grand fan des train roulant de rsv1000!!! :pain: :pain:
un travail de furieux realiser
good job!!!! :amen: :amen:
MessagePublié: 25 Mars 2012, 18:56
Not much done this weekend due to riding all day Saturday and shagging most of Sunday morning.
Got the bottom alloy sheet sections cut and fitted, I did intend to fold all the sections but folding gave a rounded corner and I want a Sharp corner so all sections will need cutting, I also have to re make the top.
MessagePublié: 26 Mars 2012, 21:34
Replaced the folded top section with seperate bits to get sharp corners and finished covering the tail ready for welding tomorrow
Made a start on the tank
